SST not showing model name in model list.
  • x3256
    • Feb 2021
    • 22
    [Misc] SST not showing model name in model list.
    Even after registering firmware with the SST ,the model select dropbox is empty please help.
    I m using win 10 and even tried using compatibility mode.
    Thanking you
  • copier tech
    • 8163
    Re: SST not showing model name in model list.
    Thanking you
    What model?
    See this recent post by our Teckat.
    how to use SST
    • x3256
      • Feb 2021
      • 22
      What model?
      how to use SST
      Model is ir adv 6255 sst ver 4.8 will it support?
      • copier tech
        • 8163
        I just tried it using SST v4.74E & IR6255 v27.04 without any issues.
        Make sure you unzip the firmware to C:\ServTool\NewROM
        • x3256
          • Feb 2021
          • 22
          [ATTACH=CONFIG]48175[/ATTACH]
          [ATTACH=CONFIG]48176[/ATTACH]
          [ATTACH=CONFIG]48177[/ATTACH]
          Thank for your support sir,
          I have tried again by re-registering the firmware but still its not showing in the connect model list although it shows in the registered firmware list maybe my firmware files are broken or incomplete.
          • copier tech
            • 8163
            Ok, so you don't see this option?
            Download a fresh copy of the firmware & try again.
            • x3256
              • Feb 2021
              • 22
              [ATTACH=CONFIG]48178[/ATTACH]
              Sir, its not showing for these models too like ir adv 6075 but irc3100 its fine.
              Thanks again.
              • copier tech
                • 8163
                Reregister a fresh copy of the firmware.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  [ATTACH=CONFIG]48179[/ATTACH]
                  [ATTACH=CONFIG]48180[/ATTACH]
                  Thanks again.
                  Download a fresh copy from sims and start over you must be doing something wrong
                  Regards Mark
                  • x3256
                    • Feb 2021
                    • 22
                    Thanks sir
                    finally it worked with fresh firmware
