E0000602-20 Canon IR dx4745i power failure
  • fbkhan3
    • May 2012
    • 421
    Hi folks,
    Hope you all doing very well, costumer had power break down and after that it doesn't boot error 602-20 pops us.
    HD shows'' OK '' in test mode.( Picture attached)
    I guess flashing firmware will solve the issue .
    I'm mostly doing Ricoh And not able to source firmware for this model . I do have the SST tool and have done few firmware for 4525i series.
    If someone could kindly help, I had great help and support from Mr. Tacket In the past.
    Regards
  • copier tech
    • 8220
    Re: E0000602-20 Canon IR dx4745i power failure
    Originally posted by fbkhan3
    Hi folks,
    Regards
    Happy to help, you can contact us at:
    Firmware Update - Printer & Copier Firmware
    • fbkhan3
      • May 2012
      • 421
      Thank you, it's great to know that it's available , I will contact you soon.
      • fbkhan3
        • May 2012
        • 421
        Hi,
        I have registerd the firmware to a USB stick, Machine booted with pressing hard Keyes 1 & 3, the panel remains on
        checking USB
        Waiting SST connection
        Starting USB Task
        any help to resolve the issue or guidance to the right direction is highly apricated.
        Regard's
        • copier tech
          • 8220
          Hi,
          checking USB
          Starting USB Task
          Regard's
          Try using the keys 2&8 to boot up in safe mode.
          • fbkhan3
            • May 2012
            • 421
            These series of mahines have smart panel,(SOP) so only 3 hard keys are available on the bottom of operation panel.
            machines boots up with E000602-20 so nothing else on screen.
            I need to format the Hard drive for that I need to go in to safe mode. but still trying to figure out how is that possible.
            I was able to go in to download mode while pressing the key 1 & 3 and booting up the machine. but as long as hard dirver doesn't get format no chances of new firmware flash.
            Regards
            • tlanza
              • Jan 2016
              • 11
              Regards
              it might work temporary it might need hdd
              if booting up take long and freezing hdd and software
              • copier tech
                • 8220
                Regards
                Read the service manual we sent you & check the troubleshooting chapter for 'remedies to be performed when E602-xxxx or E614-xxxx error isdisplayed' section.
                • fbkhan3
                  • May 2012
                  • 421
                  Thank you but I couldn't find the method to go in to Safe mode anywhere in service manual.
                  Went through all the pages where remedies to be performed and to initialize the hard disk. I guess they don't describe the method In SM anymore.
                  • hidius
                    • Jun 2015
                    • 128
                    plug the usb in
                    boot up to safe mode using the 1 and 3
                    select option 4 clear/format
                    select option 1 disk format
                    When clearing or executing format HDD, reloading the firmware is not required. Flash PCB, where the system software resides, will update necessary sectors required in the HDD.
                    • fbkhan3
                      • May 2012
                      • 421
                      Originally posted by hidius
                      plug the usb in
                      Thank you , finally I was able to format the disk and get rid of E602.
                      Tried to register the firmware on different USB stick and it worked.
                      Thanks a ton.
                      Regard's
