Canon Advance IR C3720I error e000732-0023
  • Victor H
    • Aug 2016
    • 21
    [Error Code] Canon Advance IR C3720I error e000732-0023
    Hi all, got a call to attend the Copier with error code e000732-0023. Canon advance Ir c3720i. Tried to reset but no joy. Please advise on what i can handle this matter.
    Thanks Regards,
    Victor
  • tlanza
    • Jan 2016
    • 11
    Re: Canon Advance IR C3720I error e000732-0023
    Thanks Regards,
    Victor
    you can bkup readers values in service mode
    and you can restore the values in service mode
    clear reader controller in technical service
    Reader controller pcb
    Main Controller PCB
    • Victor H
      • Aug 2016
      • 21
      Main Controller PCB
      Thanks for reply,, if you can give some more explanation especially procedures to follow. Thanks in advance.
        did you look in the service manual?
        do you HAVE the service manual?
        Canon like Xerox, you need the service manual to service manual to preform service on them.
        • fchu5959
          Field Engineer
          • Jun 2010
          • 100
          Thanks Regards,
          Victor
          hi,
          According to the service manual,the MN-con pcb is the culprit.
          On these new Dx models,you should never,never swap Mn-con pcb with other machine.you should always put on new pcb.
          I did encounter once with E0732-0023 code;in this case,the power supply board was faulty.
          So, i would suggest you try ,first,to replace the power supply board before replacing the Mn-con pcb.
          Good luck.
          • copier tech
            • 8217
            Thanks Regards,
            Victor
            Update the firmware.
            Click here download printer or copier firmware
