Hi, I went out on site to replace a toner cartridge in a Canon IR ADVANCE 4025 and once placed in the machine the toner door won't close, finally when I do get it closed you hear te cartridge feed but the machine won't detect a new Toner Cartridge it, keeps saying replace toner. Any suggestions?
Canon IR ADVANCE 4025 toner door won't close
Re: Canon IR ADVANCE 4025 toner door won't close
Pull out the toner. Manually close the toner door as if the toner is already inside. Restart the machine. Install the toner.If it ain't broke, don't fix it
A picture is worth a thousand words -
If you want to close the toner door without toner bottle, press the guide on the left with your finger.If it ain't broke, don't fix it
A picture is worth a thousand wordsComment
