canon clc 1180 multifeeder will not recognize any size paper
  • Aqua Scan
    • Apr 2021
    • 9
    Is there some settings in service mode that are needed to get the multifeeder on a clc 1180 to recognize that is has paper loaded?
    Can anyone help me?
    Thank you
    Robert
    • 22808
    Re: canon clc 1180 multifeeder will not recognize any size paper
    Can anyone help me?
    Thank you
    Robert
    1) I wouldn't go to work on ANY Canon product WITHOUT a service manual
    2) being an end user you could really mess things up messing around with Service Mode
    3) are you sure it is the correct ADF ( i guess that's what you mean by multifeeder ) for that unit and is it hooked up properly
    what have you tried?
    is the ADF new or a pull?
    who set it up?
    this is really above your pay grade. HIRE A TRAINED TECH
    • Aqua Scan
      • Apr 2021
      • 9
      I am talking about the thick paper bypass on the side that will not see any width paper 11" x 17" or 8 1/2" x 11"
      I am trying to do an auto gradiation to adjust my colors but the clc 1180 will not see the 11' x 17' paper in the cassetts or the bypass.
      Now i can send any size paper from the rip ( 650 colorpass ) to the bypass with out any problem but I want to calibrate the colors and i cant. I wonder if there is a way to auto gradiation from the rip instead of the copier. I can calibrate the rip to the copier witout and problem going threw the bypass.
        • 22808
        what is the paper size on the rip and the copier?
        what error message are you getting?
        have you tested the paper sensors in service mode?
        • Aqua Scan
          • Apr 2021
          • 9
          Paper size coming from the rip is 11" x 17" & 8 1/2" x 11" goes threw the bypass no problem.
          Copier error message say this same message no matter what paper cassett or bypass i choose-There is no loaded paper with the same size as the slide guide width. Adjust the side guide width and reset the paper size, but when i move the guides nothing happends.
          have you tested the paper sensors in service mode? No i Havent.
            • 22808
            yes I have just like every other sensor in the machine there is a procedure...
            like I said before YOU NEED THE MANUAL
            • Aqua Scan
              • Apr 2021
              • 9
              I have the CLC Manuals
              • Aqua Scan
                • Apr 2021
                • 9
                But the manual doesn't explan everything in detail. On somethings it does but a lot of error codes it tells you what it could be but not how to fix it. Is there a more indept service manual for techs only?
