I just got me an IR C5235
  • carlsson
    • Apr 2021
    • 35
    Hi there,
    I have been an IT conultant since 1995 with focus on Apple Macintosh. I have done a lot of repairs on printers as well, especially on Konica Minolta and Canon.
    So, I just got me an IR C5235 from my old work, and have started to fix some things on it. First will be to swap the PCB board, it has the "everything is unresponsive but the energy saver button" error. So I am about to order a FM1-U976-000 board.
    My post is mostly asking if anyone would like to give some expert tips about this printer? What to do, and not to do? Best place to order spare parts within EU? (eg, I need new assembly hinges)
    I would also like to get a hold of the service manual as well as firmware updates, but those questions should be posted on other parts of the forum, if I got it right?
    Thanks,
    Andreas Carlsson, Sweden
    Re: I just got me an IR C5235
    Hi Welcome to the forum
    Compared to other manufactures Canon's cassette feed tyres wear out, as soon as you experience paper jams try the same job from a different paper tray, these tyres are simple to replace, an end user could do it.
    You can update the firmware in additional functions / device administration, but if its working why fix it?
    Its unlikely you will notice any real difference with a newer f/w
    • copier tech
      • 8172
      Originally posted by carlsson
      Hi there,
      Thanks,
      Happy to help with the firmware, service & parts manuals should you wish to update.
      Click Here To Download - Ricoh, Konica Minolta, Kyocera, Lexmark or Canon Firmware
      • carlsson
        • Apr 2021
        • 35
        Thanks for the input Skynet (cool nic )!
        Is it the same pickup rollers on all trays? I could buy one or two extras to have around I mean.
        Regarding Firmware my policy is to always have the latest updates. This way I can feel confident that everything is fresh and up to date!
        And yes, it have bugged me a few times during the years, but I'm sure it's better than have old software/firmware.
        But I read you.
        • carlsson
          • Apr 2021
          • 35
          One drawback when the control panel doesn't work, is that the official User Guide that's available rely many settings on the control panel, instead of the Remote UI...
          Very well, I have a problem: I have turned on Airprint, but when trying to print with that, I am asked to give acoount credentials. How do I get rid of that?
          When printing via IP I do not have that problem.
          • carlsson
            • Apr 2021
            • 35
            One more thing: Is there any way to control the scanner functions remotely (instead of via the CP)?
              But I read you.
              There are three rollers used in the pickup assembly that can be swapped over just put them in the corresponding place.
              They look like this. Pull out the paper cassette, and you will see them, to remove open the right door and lower right door.
              The thinner gray one lasts quite well it's the other two that wear particularly the larger gray one.
              Black roller FC6-7083-000 ROLLER, FEED/SEPARATION
              Gray roller FC6-6661-000 ROLLER, SEPARATION
              As for the firmware this is how you do it,
              CANON IR-ADV FIRMWARE UPDATE ONLINE - YouTube
              • tech28
                • Jun 2013
                • 434
                Before you start sinking gobs of money into the machine, make sure you can get the firmware(hard to get here), and also, what makes you think that's the board you need? When you get the one light on the control panel, more than likely it's the hard drive. If you have never done it before, you sir is going to need a lot of help. Good Luck!
                • carlsson
                  • Apr 2021
                  • 35
                  Well all things I've read on the net about this fault indicates it's the board. I have ordered it from UK now, we will know in a couple of weeks.
                  Thanks.
                  • carlsson
                    • Apr 2021
                    • 35
                    Thank you all for the feedback and replies!
                    I have managed to update the firmware in the Remote UI, and I have also gotten the hands on a service manual (what a beast! Will be perfect to read a couple of pages per day ) . Spare parts are ordered (Front cover hinges and PCB1), and i will hopefully have a fully working copier soon.
