irc 3580 code error 602-0105
  • ernesto
    • Oct 2011
    • 430
    Hi
    I have a irc 3580 when it is starting and the bar is nearly finish error 602-0105 appears
    Does anyone knows the problem?
    I replaced hard disk and net card adn memory RAM
    i hope to hear from you soon
  • 20 year tech
    • May 2014
    • 577
    Re: irc 3580 code error 602-0105
    602 errors are hard drive related. you say you replaced the HDD did you get one from canon and did you reload the system software ?
    • ernesto
      • Oct 2011
      • 430
      I am not reloaded because I exchanged the hard disk with other machine and in the other machine the hard disk works right
      • kuby
        • Oct 2007
        • 1409
        Did you exchange it from the same model? If so then try taking the hard drive from the machine that did not work and installing it the other machine.
        • copier tech
          • 8172
          What was the error code before you swapped the HDD from another machine?
          • ernesto
            • Oct 2011
            • 430
            602 errors are hard drive related. You say you replaced the hdd did you get one from canon and did you reload the system software ?
            i replaced tha main controller and that solves the problem
            thanks for your answers
            all the best
