IR A6555i III e000025-0001
  • songela
    • Mar 2008
    • 216
    Toner supply motor M10 was replaced in the first attempt to solve this issue, but NO change.
    Had anyone come across this fault in this particular model? The machine has made just 400k images.
  • copier tech
    • 8172
    Re: IR A6555i III e000025-0001
    • Code: 025-0001-05
    • Description:Toner Feed Motor error
    • Causes:Overcurrent of the Toner Feed Motor was detected. Update the system software
    • Remedy:[Related parts] - Harnesses from the Main Driver PCB to the Buffer Unit 1. Main Driver PCB (UN78/J115) to Relay Connector (21P) (Unit of replacement: CABLE, MAIN DRIVER, REAR UPPER) 2. Relay Harness (21P) (Unit of replacement: CABLE, RELAY, FRONT) 3. Relay Connector (21P) to Buffer Unit (J3124) (Unit of replacement: CABLE, MAIN DRIVER, FRONT) - Harness between the Buffer Unit (J3124) and the Toner Feed Motor (M28/J2035) (Unit of replacement: CABLE, BUFFER) - Toner Feed Motor (M28) - Main Driver PCB (UN78) (Unit of replacement: MAIN DRIVE DRIVER PCB ASS'Y) - DC Controller PCB (UN01) (Unit of replacement: DC CONTROLLER PCB ASS'Y) [Remedy] Check/replace the related harness/cable, connector and parts. [Reference] Before replacing the DC Controller PCB, back up the service mode data (approx. 2 min) and restore the backup data after the replacement so the data may be able to be protected. - Backup: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMBUP - Restoration: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMRES
    • songela
      • Mar 2008
      • 216
      • Code: 025-0001-05
      Thank you for the suggestions.
      Let me see if I will be lucky with the first line of approach.
