iR ADV C3520i Gen 1 - "Ghosting"
  • TA_Tech
    • 76
    Hey guys
    need some suggestions with a pretty baffling problem. See Sample 1 for problem. Note arrows at bottom of page indicating feed direction of the paper when printing.
    Sample 1.PDF
    Sample 2.PDF
    I noticed the following while testing:
    • Ran test prints like sample 1 with a color block for each of the colors (C, M, Y, and K block) with colored text below the block. Problem from sample 1 only happens with Cyan and Magenta block.
    • Ran same test prints with C, M, Y, and K blocks, but with black text below block. The problem does not occur on any of the prints. See Sample 2
    • Ran test prints with Black block, but this time with C, M, and Y text below block. The problem does not occur on any of the prints
    • Grayscale block with black and colored text below - problem is there
    • Single color prints for each color (Cyan block + Cyan Text, Yellow block + yellow Text etc) the problem is not there
    • Adjusted paper type to Heavy 3 but printed on normal paper, for sake of increased transfer, increased fuser temp, and slower speed for more time in fuser, but problem is still there.
    • Repitition of problem is 94mm apart which is circumference of drum.
    • Swapped Yellow and Magenta Drums and Cyan and black drums (unaffected colors from earlier tests). ran same test as above and got same results.
    • Adjusted pre exposure settings in service mode - made no difference.
    looking at the above test results, i am thinking to replace the Cyan and Magenta developers, and maybe the drums for Cyan and Magenta too just for good measure, but I'm not entirely convinced of my diagnosis yet. The reason I'm thinking Devs is because although the distance in repitition is the drum diameter, and it is only on Cyan and Magenta, the problem didn't move to other colours when i swapped the drums with the other colours. Also, if it was fuser or ITB it wouldve affected all colours.
    The other reason that I am thinking developer, is this machine has always only used OEM toner, but recently generics were used because of stock shortage of OEM. The users can't remember which colors they used generic toner on, but my guess is Cyan and Magenta.
    Any suggestions or help will be appreciated.
    Thank you
  • Canuck
    Tech Specialist
    • 1713
    Re: iR ADV C3520i Gen 1 - "Ghosting"
    Machine meter? Drum counts? Run test page 10, then shut off 3 colors at a time in pg 10 and see what you get. Shouldn't need incorrect paper registration,etc. Looks like drums to me..contaminated primary roll, drum fatigued and having memory...not devs IMO. Did you verify pre-exposure is coming on...
    • TA_Tech
      • 76
      Thanks for input. Much appreciated. To answer questions:
      Meter: 1.7 million in a 40/60 split for color/mono
      I have tried the PG10 on single colors - no problem
      I did not check if the pre-exposures come on - i only adjusted intensity. Will give that a go.
      I did think of drum fatigue and memory, which is also why I swapped drums around, but the problem remained on Cyan and Magenta and didn't move with the drums, and also as mentioned, if it were ITB or fuser it would be all colors, so that is why i am of opinion it could be contaminated devs.
      • copier tech
        • 8131
        Originally posted by TA_Tech
        Hey guys
        [ATTACH]49041[/ATTACH]
        [ATTACH]49040[/ATTACH]
        Thank you
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Hey guys
          Thank you
          Sounds like toner to me
          Regards Mark
          • bret@cos.flag.org
            • Jun 2020
            • 98
            Sorry I can't offer more advice than the others, but I've never used generic toners on a Canon copier and I've never seen the problem you're having. I'd have to agree that the generic toners are suspect.
