Cause for repeating black spot?
  • bret@cos.flag.org
    • Jun 2020
    • 99
    #31
    Re: Cause for repeating black spot?
    Thanks guys for your advice and concern.
    If only it were that simple...
    Covid is preventing me from going there, factually. I have very limited access, only after hours and only on a really as-needed basis. They want to handle as much as possible themselves - really as much as possible. It's not a traditional technician/customer setup here. It's a long story, made longer with covid.
      Originally posted by bret@cos.flag.org
      I got an opinion from another tech that since the drum was recently changed, that it is probably that the drum is mis-aligned which would cause that issue. He suggested to open it up and pop out and re-insert the black drum. Then re-run the Auto Correct Color mismatch procedure.
      Always question what you did IF there is a problem after the service.
      But I first suggest using the wood cabinet makers rell me, measure twice .. cut once. (In other words double check your shit)
      My 2 cents.
        If the sensor is dirty it will happen on a daily basis. Get the hell out there and clean the damned sensor before you lose a customer.
        +1
          Wait you're in FL and there are covid restrictions? Local or company?
          DeSantis has had the state open.
            • 37488
            #35
            Maybe he is bsm2's cousin.
              • bret@cos.flag.org
                • Jun 2020
                • 99
                #37
                Self imposed covid restrictions, far more strict than government restrictions. Folks susceptible to illness. Their call, not mine.
                I completely agree with you guys. I'm not trying to skip out of the job or skimp it in any way. But in this case their health is more important than the operation of the machine. Each time I go there, and the longer I stay, is considered a health risk for those folks.
                We're all crossing our fingers that it stays working. If not I'll schedule going back (well after normal working hours) and will re-check the drum alignment and clean the sensors.
                  • 37488
                  #38
                  Email them our suggestions and a PDF copy of the service manual and let them decide if they want you to do or if they want to. You may have send the service as a link to a cloud drive if it is too large. If you use gmail it does it for you.
