C5250 E020-0391
  • repeatcopiers
    • Sep 2008
    • 591
    C5250 E020-0391
    Have a C5250 that was sitting for awhile, now customer is using it and got a E020-0191. We replaced the Yellow developer then a day later they received E020-0291, so we replaced the magenta developer, now they are getting an E020-0391. It will pass 1 copy then the 2nd copy causes the code. Is it possible all these developers have gone bad or should I be looking at something else.
  • copier tech
    • 8131
    Re: C5250 E020-0391
    I would strip out all the drums, dev & ITB clean/vacuum out any stray toner clean the patch sensors check each dev unit turns freely by hand re fit all the parts run auto gradation then run say 50 duplex blank prints see if this helps.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Re: C5250 E020-0391
      Did you fit new oem dev unit
      Regards Mark
      • repeatcopiers
        • Sep 2008
        • 591
        Re: C5250 E020-0391
        Thank you, will try that.
        • repeatcopiers
          • Sep 2008
          • 591
          Re: C5250 E020-0391
          I used a working developers out of a demo unit I have. The yellow and magenta worked fine and code cleared right away but the cyan did not. Also pulled the cyan toner hopper and found a piece of the mylar was loose and blocking part of the opening. Removed that but still getting same E020-0391.
          • copytech,mike
            CopyTech,MIKE
            • Jun 2014
            • 261
            Re: C5250 E020-0391
            Sounds like you need a new Cyan Dev unit. I know they are a rippoff and overpriced but you gotta use a new unit. Had a customer use non oem toner once and i was able to save it by putting in correct toner and running sky shots inbetween it coding out. Then rand inset adjust and it was fine. However that was only for blk dev unit. Color might not work. Did you check your toner? Is it Genuine Canon?
            • copytech,mike
              CopyTech,MIKE
              • Jun 2014
              • 261
              Re: C5250 E020-0391
              It has bad toner. Dont think you have 4 bad dev units. Try fresh toner. Run as many color copies as you can. Get that fresh toner pumping. You can also clear the dev counters and run the install inset. Did aftermarket toner get put in this machine?
              • repeatcopiers
                • Sep 2008
                • 591
                Re: C5250 E020-0391
                New cyan developer did the job, thanks for your help.
                • copytech,mike
                  CopyTech,MIKE
                  • Jun 2014
                  • 261
                  Re: C5250 E020-0391
                  Good job!
