Canon iR ADV C5255 - Ploblem
  • luis1984bol
    • Nov 2011
    • 155
    [Misc] Canon iR ADV C5255 - Ploblem
    Hello.
    I have a problem with a Canon iR ADV C5255. As you can see in the image Foto Rev.jpg
    I had replaced, two times, the Magenta Develop Unit ( Not new) and the problem was solved for a few days and then again.
    Do you have any idea what could be the solution?
    Thanks.
  • Brian8506
    • 1665
    Re: Canon iR ADV C5255 - Ploblem
    Did you replace the magenta drum?
    • luis1984bol
      • Nov 2011
      • 155
      Yes, I did. But the problem persist.
      • copier tech
        • 8174
        Originally posted by luis1984bol
        Hello.
        I have a problem with a Canon iR ADV C5255. As you can see in the image [ATTACH=CONFIG]49376[/ATTACH]
        Thanks.
        Are you using genuine canon toner?
        • Benjamin98
          • Mar 2015
          • 89
          Hello.
          Thanks.
          Hi there, just to clarify you can't generally use old developing units. Maybe once to test but not as a lasting solution.
          How is the PG10? Maybe replace the Magenta dev with a brand new one and don't forget to do the INIT-M
          • luis1984bol
            • Nov 2011
            • 155
            Yes. Toner, Drum units and Dev units are all genuine.
            • luis1984bol
              • Nov 2011
              • 155
              [QUOTE=Benjamin98;1795181]Hi there, just to clarify you can't generally use old developing units. Maybe once to test but not as a lasting solution.
              How is the PG10? Maybe replace the Magenta dev with a brand new one and don't forget to do the INIT-M[/QUOT
              You are right. I used them for test. I am going to change a New one in a few days.
              I am worry it Will not work. I will let you know the result.
              Thanks.
