SMB scanning for ADV C5051
  • lionex3d
    • Jun 2013
    • 41
    would C5051 be able to support smb2 scanning if it is upgraded to the latest firmware? or it is only bound to smb1?
    thanks in adv
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: SMB scanning for ADV C5051
    Also smb2.
    • lionex3d
      • Jun 2013
      • 41
      Originally posted by zoraldinho
      Also smb2.
      so it only needs a firmware upgrade?
      • techandtrader
        • Jun 2016
        • 335
        Yes They solved all that with an update.
        I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
        • beaker020
          • Mar 2006
          • 63
          You need special firmware V83.68.01. This is not general release firmware and any attempt to upgrade this firmware will remove this functionality.
          • sharpie
            • Feb 2011
            • 182
            I also need SMB2 support for a client that has several IR-C5240A's. We are not a Canon dealer, is there somewhere they could download the specialty firmware?
            • copier tech
              • 8174
              Happy to supply this so should you need it please contact us at the links below.
              • lionex3d
                • Jun 2013
                • 41
                Please contact copier tech, i solved mine with his help
                • dekoster
                  • Aug 2012
                  • 84
                  simply on the pc in the search bar windows features
                  enter
                  open folder
                  then under (support for SMB 1.0 / cifs file sharing
                  insert all hooks
                  • zoraldinho
                    • Mar 2008
                    • 5015
                    enter
                    open folder
                    insert all hooks
                    So easy? Seriously?
                    Notably, SMB1 was used as an attack channel for both the WannaCry and NotPetya mass ransomware attacks in 2017.
                    • dekoster
                      • Aug 2012
                      • 84
                      yes that easy
                      • dekoster
                        • Aug 2012
                        • 84
                        but you can also install the special software
                        • dekoster
                          • Aug 2012
                          • 84
                          • dekoster
                            • Aug 2012
                            • 84
                            yes that easy
                            • zoraldinho
                              • Mar 2008
                              • 5015
                              yes that easy
                              Why are you translating my English words into German?
