Canon IRA C5540i Controller and HDD location and compatibility
  • doug
    • Dec 2011
    • 198
    Hi guys
    This is the continuing note from the previous post of The canon iRA C5440i with the blinking energy save button.
    Are the Main controler and HDD the same as a 555Oi?
    And where are they located on the machine?
    thanking all of you in advance .
  • copytech,mike
    CopyTech,MIKE
    • Jun 2014
    • 261
    Re: Canon IRA C5540i Controller and HDD location and compatibility
    Originally posted by doug
    Hi guys
    You don't know what the hell your doing. The copiers HDD has nothing to do with the main print controller.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5013
      You can't just swap hdd from other printer
      without firmware.Main controllers are different.
      • copier tech
        • 8144
        Hi guys
        If the HDD was the issue you would get an E602 error.
        Check the parts catalogue if the C5550 & C5440 main controller part number are the same you can swap them but I doubt it.
        • copytech,mike
          CopyTech,MIKE
          • Jun 2014
          • 261
          Buy a used HDD from Ebay from a known working machine and leave the print controller board alone.
          • alex@wocltd.com
            • 430
            wont work - hdd on this range are paired to individual machine so not swappable
            • copier tech
              • 8144
              You can fit a used one but first just need to delate all partitions in a HDD caddy then format the HDD using the SST & firmware.
