Opinions on what the problem is
  • bret@cos.flag.org
    • Jun 2020
    • 98
    [CQ] Opinions on what the problem is
    Hi All,
    I will be visiting this machine shortly. I'd appreciate any input on what this might be. A drum issue? Something else?
    This is on a Canon IR ADV DX C5760. It hasn't had service in several months. Firmware was updated to the latest at last visit about half a year ago.
    Thanks,
    Bret
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Opinions on what the problem is
    The picture is awesome.
    They would help if they knew the format of the sample.
    On the left sample i see bad drum or developer if you have non oem toner.
    Print PG-10 test to see wich color have issue.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Originally posted by bret@cos.flag.org
      Hi All,
      [ATTACH=CONFIG]49479[/ATTACH]
      Thanks,
      Bret
      Better samples would be good what's drum life
      Regards Mark
      • bret@cos.flag.org
        • Jun 2020
        • 98
        Thanks.
        I know the photo is not the best. I think they were trying to not show their entire document.
        Apparently the problem cleared up.
        Hopefully next week I can check it out. I'll assume it's a drum or developer and have those on hand in case needed.
        • Canuck
          Tech Specialist
          • 1713
          Meter reading on machine?
          • bret@cos.flag.org
            • Jun 2020
            • 98
            Hi guys,
            Following up on an old thread here in case it helps someone in the future. In the end the solution was a new black drum.
            The counters were just over 600,000 at the time. I believe that was the first time the black drum had to be replaced since they got the machine.
