Ir 2016
  • saintphotostat@gmail.com
    • May 2016
    • 10
    [Error Code] Ir 2016
    Fan error E805 on an ir 2016 but fan runs for a few seconds before initialisation then stops at this point machine also runs then shows error what could be the reason is it connected with power suply ? Thanks in advance (inthis is the first attempt on office copiers service started with a dead machine after correction of strip cable from power supply to DC con it started giving copies , error occurred after vivid lock down)
  • copier tech
    • 8172
    Re: Ir 2016
    Have you tried to remove/clean/tube the correct fan?
    If you have they you may need to replace it.
