ADF Scans blurry with horizontal colored lines on c3325i
  • sternmd
    • May 2024
    • 5
    Hi,
    Our c3325i has recently developed a strange symptom only on ADF scans and copies and not at all on scans and copies from glass.
    The output from ADF is blurry, dark, and full of horizontal colored lines. Image: https://imgur.com/a/1SFs3F0
    I've run ADF cleaner mode several times, have cleaned ADF glass with cloth wipe approved glass cleaner.
    Is there anything else I should be doing?
    The machine had new drums, new transfer belt installed a couple of weeks ago. All prints are normal.
  • dalewb74
    • Feb 2018
    • 1153
    have you opened it up and cleaned the optics? i might be missing it since i am trying to learn the new configuration of the new website. but did you state the model?
    • sternmd
      • May 2024
      • 5
      Thanks - yes the model is Canon ImageRunner c3325i - I will open it up and clean the optics. Good idea.
      • David Morrison
        Digital Tech II
        • Feb 2010
        • 43
        Try white adjustment. I had a similar problem last week and that fixed it.
        • sternmd
          • May 2024
          • 5
          Thanks - I did this just now and got OK for glass on white adjustment.
          For ADF DF-WLVL2 white adjustment, I get NG! error.
          I used this function BTW
          [Service mode]
          COPIER > FUNCTION > CCD > DF-WLVL1 (copyboard)
          COPIER > FUNCTION > CCD > DF-WLVL2 (DF)
          I can't find in service manual what that NG! means in this function or how to get to the specific source of that error code. Any ideas welcomed.
          • David Morrison
            Digital Tech II
            • Feb 2010
            • 43
            NG is no No Good. Is the problem only on the back side or the front?
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5013
              Poor quality scan, but the lines seem to be of different colors. This could be a flat cable.
              • sternmd
                • May 2024
                • 5
                Thanks - just to make sure I understand: do you mean that the cable from ADF assembly to board needs to be replaced or just moved/re-seated?
                • sternmd
                  • May 2024
                  • 5
                  Thanks - it's only bad on the scanned side (one side)
                  • David Morrison
                    Digital Tech II
                    • Feb 2010
                    • 43
                    I think that model scans the front and back at the same time. If it's the back side that's the problem, I'd replace the scanner unit inside the feeder. If it's the front side, maybe there's something wrong with the white plate next to the glass.
