canon imagepress C 700 fiery iPR srv G100 password incorrect
  • fariddz18
    • May 2024
    • 2
    [Error Code] canon imagepress C 700 fiery iPR srv G100 password incorrect
    I have a problem acces to fiery command workstation after changing the motherboard. The program asks for the password, and when I enter the default password Fiery.1, it gives me an error. Is there a solution to reset it? soryy for my english help me pls to fix it thx
  • bobburnsreb
    • Mar 2015
    • 233
    Print out the config page and find password.
    • fariddz18
      • May 2024
      • 2
      I printed the config page. Can you explain how to find the password pls
      • bobburnsreb
        • Mar 2015
        • 233
        Sorry, I posted the wrong answer. Fiery.1 should work.
        • bobburnsreb
          • Mar 2015
          • 233
          Try this: IMPORTANT:Do not use this password when you log on to the Fiery server for the first time. Instead, print a Fiery Server Configuration page and look for ID in the BIOS Setup section (listed under RIP).
          For additional Fiery password information, go to www.efi.comNote
          1. Print a Fiery Server Configuration page, and look for ID in the BIOS Setup section, listed under RIP.
          2. For a stand-alone Fiery server, the default password is listed in the ID field. For the integrated Fiery server, the default password is the first 14 alphanumeric characters listed in the ID field. The password is case sensitive.
