hello I have a canon dx8786 which presents an image quality defect after reinstalling the system. the image is too light when printing and copying. can anyone help me to solve this problem. THANKS
Canon dx 8786 image quality defect
Try:
Run Copier>Function>Install>Stir-K
Make sure Potential Control is set to on Copier>Option>FNC-SW>PO-CNT=1
Run DPC2 Copier>Function>DPC To execute potential control without power cycle of device.
Check Copier>Display>DPOT>VL1-T / VL1-M The M-measured value should be close to the T-target value (voltage in the light Laser.)
VDT / VDM VDM value should be close to VDT value (voltage in the dark Primary charge.)
Good Luck!
Copy>Function>Install>Stir-K. does not exist among the elements of the install function
Make sure Potential Control is set to Copier>Option>FNC-SW>PO-CNT=1.yes it is 1
Run DPC2 Copy>Function>DPC To run the potential check without restarting the device.
Check Copier>Display>DPOT>VL1-T = +190V
VL1-M=+186V
The value VDT / VDM VDM =+495V
VDT = +490
printing and photocopyi dataurl903561.png always remain pale
dataurl903561.pngComment
I had a similar problem. I had to replace the hvt.
There are three together on the tray at the back.
If the image on the drum is ok=transfer hvt
If the image is also bright on the drum = developer hvtIf it ain't broke, don't fix it
A picture is worth a thousand wordsComment
