Canon IR ADV C5240 - Scanner Problem
  • luis1984bol
    • Nov 2011
    • 148
    [CQ] Canon IR ADV C5240 - Scanner Problem
    Hello:
    I have a problem with the scanner unit. As you can see in the video (https://youtu.be/mcpwKTqGTZ8), the scaner goes to the left instead to go to the rigth. It happens when I try to copy or scan from the glass. The ADF woks fine.
    I have already checked the sensors, the motor and they look fine. I have uploaded the firmware too.
    It is weard because it does not show any jam or code error.
    Could you please help me with this problem?
    Thank you!!!!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Canon IR ADV C5240 - Scanner Problem
    The scanner is in the scanning position from the adf.
    In service mode, check if any sensor is on.
    You can try clearing the reader cont. Save the settings first.
    • dekoster
      • Aug 2012
      • 84
      Originally posted by luis1984bol
      you have the sensor hook at the top left of the scanner
      that must be pressed down
      • luis1984bol
        • Nov 2011
        • 148
        I was thinking the same, so then I had unplugged the ADF ( all conectors). And the problem persist without the adf.
        I did the CLEAR Dcon, Rcon all of them.. And nothing
        • luis1984bol
          • Nov 2011
          • 148
          I had tested the motor that control the CIS in service Mode, and it does the same. The CIS tries to go to the left intead to the right.
