Canon ir c4080 panel dead, power led ON, imagePASS dead
  • raphgoingto
    • Jul 2021
    • 11
    [Dead] Canon ir c4080 panel dead, power led ON, imagePASS dead
    Hello,
    I have a big problem with my canon ir c4080, the machine was in normal operation and suddenly it turned off, when I turned it on again I found a dead panel (not even the keys work) and the imagePASS does not turn on either (it does not receive a boot signal ).
    The POWER led on the panel is on and the machine performs the complete preheating cycle.
    I tested the imagePASS and the panel on another machine and they worked correctly, on this machine I have checked all the connection cards, change RAM memory, BootROM and all the cards associated with the PCB. Also replace primary and secondary source, nothing has worked.
    I need tout help, sorry for muy terrible english. Thanks un advanced
  • Hishamawada
    • 174
    Re: Canon ir c4080 panel dead, power led ON, imagePASS dead
    Hello ,
    it is a main controller issue. if the issue still occurs again you will need to reinstall the firmware
    Sent from my SM-G610F using Tapatalk
    • raphgoingto
      • Jul 2021
      • 11
      Originally posted by Hishamawada
      Hello ,
      Oh, must I change the box completely? Going to
      • Hishamawada
        • 174
        just change the big main board , but you must keep the small boards from the old one .
        • raphgoingto
          • Jul 2021
          • 11
          Ok, going to try... Thanks
          • raphgoingto
            • Jul 2021
            • 11
            Problema Solve! Thanks you so much Hishamawada!
