user management on c3325i turning it off
  • mrfixit7
    • Jul 2018
    • 40
    [Misc] user management on c3325i turning it off
    the option under user management is unavailable, ive searched service mode and settings/registration.. i cant see how to allow turning user management off.
    any help is always appreciated
  • copier tech
    • 8176
    Re: user management on c3325i turning it off
    You can configure the settings for managing users of the machine with a user authentication application.
    • mrfixit7
      • Jul 2018
      • 40
      doing exactly as i usually would i can see where to turn of user authentication. the machine will not allow it. its unavailable / gosted out
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        You need to log in with administrator credentials to access it
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
        • mrfixit7
          • Jul 2018
          • 40
          so im logged in as administrator on the machine, go to user management to turn it off like i do with all the machines im refurbishing and programming before they go in the field.
          but when i go into turn it off i cant it is not in bold like it usually is. its greyed out,at the machine or using a computer threw the ip address still not an option .. anyone know how to tag teckat? that guy knows everything....
          • Venom
            • Nov 2009
            • 765
            You can try going to RUI, SMS (system management service).
            Enhanced System Application Management to switch log in, maybe look in System Application Management to see if service needs to be Stopped
              Since your refurbing it, you won't care if you loose n/w settings > clear the MMI in service mode
              • mrfixit7
                • Jul 2018
                • 40
                so i tried turning this off.. now i cant log in at all RUI any clue how to reset the entire machine. ive MMI cleared it as well no effect on user management
                  This is an advance machine yes? what about initialize to factory defaults?
                  • dekoster
                    • Aug 2012
                    • 84
                    log in to the menu
                    Administrator
                    Password: 7654321
                    • 20 year tech
                      • May 2014
                      • 577
                      Level2 Option>User>AFN-PSWD> 0
                      • mrfixit7
                        • Jul 2018
                        • 40
                        ok, so i gained access to rui by defaulting printer under additional functions. i can now log in via RUI and into device manager under additional functions however im still not able to turn off user management.
                        ive mmi cleared , password cleared , defaulted printer under printer settings.
                        thanks for all the suggestions guys, please let me know if you have any other ideas
