Canon iR c3330i - Error E602-0701
  • Slody4Futbol
    • Jul 2021
    • 1
    Hi,
    I'm on a ship at sea and we currently have one of our copy/scan/print machines not working. When you turn the power on it shows the loading bar, then goes to a black screen with "E602-0701" and asks to turn OFF the power.
    From what I can find it seems to be a hard drive issue.
    We have some spare 2.5" SATA hard drives on board that I could probably use if this hard drive is bad. Could I just clone a drive from one of our other C3330i machines and install in this one and call it a day? Or is there some other recommended thing to do?
  • kuby
    • Oct 2007
    • 1414
    Re: Canon iR c3330i - Error E602-0701
    You can try cloning but the Canon's are ready picky about which hard drives you use and not had much luck in cloning a Canon hard drive. Not just any hard drive will work. Needs to be a supported Canon hard drive for that model.
    • kuby
      • Oct 2007
      • 1414
      You can try holding down the 1&9 and Powering it on and see if it will go into a Scan repair on the hard drive. Some will and some will not.
      • 40yearsplus
        • May 2020
        • 113
        Swap out the HDD with the one that works on the identical model you have in the shop.
        Then turn it on and see what happens should work.
        GL
        • copier tech
          • 8222
          Originally posted by Slody4Futbol
          Hi,
          Try reloading the firmware in safe mode.
          Create a system software USB pen with the SST then power on the machine holding down 2&8 then choose overwrite all.
