CANON IR ADV 6065 Jam and Error E537 8001
  • miguell
    • Apr 2012
    • 3
  • bobburnsreb
    • Mar 2015
    • 233
    E537 -8001 -05 Title Rear aligning plate home position error (Finisher-E1)
    Remedy
    1. The Aligning Plate Rear Home Position Sensor (PI107) is
    faulty.
    2. The wiring between the Finisher Controller PCB and
    Aligning Plate Rear Motor is faulty.
    3. The rear aligning plate is faulty.
    4. The Rear Aligning Plate Motor (M104) is faulty.
    5. The Finisher Controller PCB is faulty.
    Description The aligning plate does not leave the Aligning Plate Rear
    Home Position Sensor when the Alignment Plate Rear Motor
    has been driven for 4 seconds.
    • bobburnsreb
      • Mar 2015
      • 233
      I'm sending you an attachment containing a layout of the aligning plate.
