E00061-0001 adv c7260i
  • romario
    • Jun 2020
    • 191
    [Error Code] E00061-0001 adv c7260i
    Me. This code happened. E61-001. Adv c7260i. The copier was perfectly well tested. I travel to another city to install and I happen this code where the client. Already change primary crown 3 times and follow the error. Someone with an idea to help me.
    thanks
  • Hishamawada
    • 174
    Re: E00061-0001 adv c7260i
    Hello ,
    My friend this error is one of the most various errors.
    Since it was working properly then i suggest there is a loose connection on one of the pcbs.
    Remove and connect back all the connections for :
    -Primary Charging High-Voltage PCB (bk)
    -Dc Controller interface PCB
    -DC controller PCB.
    then update me with the results , if didnt work we will go further with the error
    Sent from my SM-G610F using Tapatalk
