Canon IR C356if flash drive issue
  • joelcarrara
    • Jan 2017
    • 49
    Hello! I'm having an issue with a customers IR C356 with recognizing a flash drive. I did enable the use of the flash drive to scan and print and when I insert it it does not recognize it. Any ideas? I did test it out the same flash drive on a Xerox Copier (unforrunately no other Canons were available) and the Xerox did recognize it. Thanks
  • ADV COPIER
    Pemain
    • Nov 2022
    • 256
    Try another FD with 2.0 FAT32 format
    Let's Drink our Coffee
    WhatsApp +62895325228383
      • 8164
      Canon can be a bit fussy with USB pen drives. Updating the firmware seems to help with the issue.
      • joelcarrara
        • Jan 2017
        • 49
        Thank you! I will try
        • joelcarrara
          • Jan 2017
          • 49
          Update-I did a full initialization and that did the trick. Both usb flash drives now are recognized. Thanks both for your help!
