C2020 E00025-300 error
  • 702stever
    • Mar 2024
    • 21
    [Error Code] C2020 E00025-300 error
    Hello all, trying to help out with one of these machines. From what I can read, they are not very well liked. Just trying to help out a friend, not certain where to begin. The fuser assembly was replaced and this error appeared.
    Tia!
  • 702stever
    • Mar 2024
    • 21
    • Brian8506
      • 1664
      You can go to service mode under display/err and it will give likely causes. That sounds like a hopper code. You can also check previous codes to see if it’s been a problem.
      • 702stever
        • Mar 2024
        • 21
        TY Brian8506 looking for service manual now...
        • Brian8506
          • 1664
          Settings registration/2and 8 at same time/settings registration/ mode list/copier/display/err
          • 702stever
            • Mar 2024
            • 21
            Thank you for your help Brian8506 I was able to resolve the issue although nowhere near the toner system, went in with candor blue everything out reseat developer units, and the fuser assembly, all good.
            • copier tech
              • 8144
              • Code: E025-0300
              • Description:Toner Supply Motor (Bk) lock detection
                The Rotation Sensor does not detect rotation although 5 sec has passed since the motor was turned ON
              • Remedy: Update system software. Overload of the motor or motor failure 1. Check conduction of FU9 on the DC Controller PCB (UN09). 2. Check the harness/connector between the DC Controller PCB (UN09/J26) and PS09 3. Replace the DC Controller PCB (UN09) 4. Check the Hopper Unit (Bk). 5. Replace the Hopper Unit (Bk).
