Yes you can. TDS uses B5 developer previously, but oce changed few years ago and there is one developer for all oce digital printers till 7m/min -so also toners are the same -only bottle, weight and price are different (oce digital not analog !!!)
So drum from PW340/345/360/365/300/350/700/750 is exacly same as TDS series -even you can use same drum for old analog oce copiers like 7050 and TDS100 -this code number is 106009321.
Only Plotwave 450 and newer can use other PN drum which phisically is the same, but difference is on left and right plastic distances -if you put to wrong machine it don't work or in other case damage drum ;(
B4 dev was used in Oce 9400 -but it also can be used in newer machines -from over 20ye experience
