Canon IRC5550i connection to network
  • skibum
    Independent Service Tech
    • 231
    I just received this machine pre owned IR5550i II and cannot connect to the network. I cant ping it from computer. Is there a problem with the main control pcb FM1-W954-000. Has anyone had this fail?
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Canon IRC5550i connection to network
    Did you enable and set an IPv4 address?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • skibum
      • 231
      I turned on IPV4 and set ip address to a known ip address used for the old Canon IRC5045 copier it was replacing and couldn't connect. Added IPpv4 address, subnet mask (255.255.255.0), and the gateway then tried to ping the Canon IRC5550i with no reply. Tried to ping the network from the Canon ("ping" on touch screen) with "no response".
      • Venom
        • Nov 2009
        • 765
        Set static IP on your laptop and connect directly, can you ping either way?
        • skibum
          • 231
          I should have mentioned that I tried to ping directly with a static ip using a direct connection of a crossover cable with no replies.
          • Venom
            • Nov 2009
            • 765
            Usually the cable get pulled out and causes the network port on the main board to get damaged, have not had board failure cause that. Try the USB connection, if it works...the board is fine.
            • alex@wocltd.com
              • 430
              have you tried wlan?
              • copier tech
                • 8142
                Try turning on IPv 6 & set DHCP & Auto IP to on see if it picks up & IP address from your network & do you get both leds on the LAN port flash etc?
                • giogi
                  Engineer senior
                  • Jan 2016
                  • 181
                  try going to
                  PREFERENCE>NETWORK>TCP/IP SETTINGS/IPv4 SETTINGS>PING COMMAND
                  and enter 127.0.0.1 (loop back)
                  if you get Responce from the host the Main Controller work well
                  "Knowledge is a source, but unfortunately ignorance is a sea."
                  • skibum
                    • 231
                    I reset any apps on this Canon C5550i to factory settings cleared the data. When i hooked up to my lap top with a direct connect (laptop, cat5 cable and copier - direct) then I can ping it with quick fast all 4 responses ok and I can I can print to the Canon.. If I hook into the customers network then I get very spotty responses back when pinging.....lost 2 of 4 responses or only get 1 response.
                    If I can print and ping the device consistently when directly connected, does this mean it is definitely a network problem in their network? Printer or Network?
                    ???? A older Canon IR C5045 plugged into the same spot replies back to me fine using the same ip settings but the Canon IRC5550i a much newer product can not be reached??? Please if someone can shed some lite. Is it a security setting within the clients network?
                    • skibum
                      • 231
                      I am using static ip only for all past posts. DHCP did not pull up any ip when trying it and since was turned off.
                      • Venom
                        • Nov 2009
                        • 765
                        Customer may be using mac address reservation. If it works directly from your laptop then the Canon is working properly. Try choosing a static IP address number that is unlikely to get duplicated with DHCP. example 192.168.1.240 The last octate idealy should be outside of the DHCP range.
                        • zoraldinho
                          teacher-guide-expert-guru
                          • Mar 2008
                          • 5007
                          I put the printer on the "wifi only" connection. On the phone, turn on the access point. Do a COM-TEST and if it is successful, the settings on the printer are ok. The problem remains on the user's network.
                          • misganaw
                            • Jan 2021
                            • 5
                            Bro there is no issue with your printer pcb, i faced same issue. all you have to do is after assigning the IP address switch off the printer from main power source, unpug the power cord wait 1min the switch on the printer and plug in network cable and ping , it should work fine.
