Canon IR Advance c2030 new drum error
  • mcbob500
    • Feb 2013
    • 16
    I installed a new oem black image unit but it did not intialize, but life counters cleared. Now error e000020-1360.
    HELP
  • copier tech
    • 8220
    Re: Canon IR Advance c2030 new drum error
    HELP
    Make sure the patch sensors & the laser glass are clean.
    • Brian8506
      • 1667
      Did you try putting the old drum back in to see if you get the code?
      Sent from my iPad using Tapatalk
      • copier tech
        • 8220
        E020-1x60 immediately after replacing the drum unit.pdf
