canon iR3300 cannot fax out
  • sgcopiertech
    • Aug 2025
    model: Canon iR3300
    problem: cannot fax out
    I have a problem with a Canon iR3300 Fax function.
    it is connected to a PABX. tested the fax line and it is
    working. the machine was tested in the workshop and
    it is working. the machine can recieve fax, but cannot
    send. it will just prompt "busy / no signal". i changed
    the fax unit but to no avail.
    i have found a workaround, after pressing the fax,
    must press the "on hook" button first, key-in the recipient
    fax number and then press "send" (green button).
    however, this will not work when your using "PC to FAX".
    any suggestions?
    • 23009
    Have you tried inserting a few pauses after the "9" to increase your chances of getting a connection within the 35 second T1 timer? You can also add some pauses after the phone number to extend the time of the T1 timer. =^..^=
    • sgcopiertech
      I will try this
      thanks for the response
      • sgcopiertech
        i tried adding a pause from 1 to 15,
        all test failed.
        any other solutions?
          • 23009
          Hane you tried plugging in an analog phone and just listen to what you get when you dial? There may be a bad card in the PBx. =^..^=
          • ps/pcl
            TECH SPECIALIST
            • Jun 2008
            • 35
            SOLUTION
            Remove the jumper on the fax board AND switch on the machine.
            it will pop a error .
            never mind ,switch off again and put the jumper back and
            switch the machine on and try faxing, it wll work out.
            ALL THE BEST
            • sgcopiertech
              i haven't return to the customer place but one things confuses is me
              is why the fax working on our workshop and not on the customer place.
                • 23009
                Most likely the problem is with the quality of the phone line, not the hardware.
                I don't know if you've listened to the quality of the line, but not all line quality issues are within human hearing range. Additionally, dropouts are the absence of signal so there's nothing to hear, literally.
                My advise is to get the customer's telephone service provider involved. =^..^=
                • creatinchaos
                  Fax Issue
                  First did you check the fax board for a dial tone? On the Fax Tab, select on-hook and listen for a dial tone. I know some of these suggestions are the basics but need mentioned.
                  Second, make sure the customer is NOT using DSL service on that line. I have found this issue many times; customer gets DSL installed and no filter is placed on the line for fax.
                  Third ask the customer if they require a special number, i.e. 9, for an outside line before dialing your number. Also check to see if a palse (P) is needed, not usual but you could encounter this in some locations. Check your dialing rules for your area. Sometimes the number 1 before the phone number needs to be dialed, i.e. 1-888-8888.
                  Forth if you need to, perform an ALL CLEAR in service mode. On most models I think the procedure is:
                  1. Enter Service Mode.
                  2. Select Fax, select Clear, and select All.
                  Clearing the board will FIX a lot of issues!
                  Last...reset your fax board! Sometimes the shifting and banging around of the equipment during delivery can make a bad contact with your fax board.
                  Good luck, and please let us know what fixed your issue.
                  • sgcopiertech
                    im going to the customer place this afternoon, ill keep u updated.thanks!
                    • sgcopiertech
                      ok, so i went to the customer place and bring 1 stand alone fax machine.
                      send / receive both ok
                      @blackcat4866
                      I plug in an analog phone, listened to the line and didnt find anything unusual.
                      @creatinchaos
                      so i went back to the 3300, do a "clear all" then setting for sssw, num and type.
                      send failed
                      receive ok
                      @ps/pcl
                      remove the jumpers and received E674, clear then put again.
                      send failed
                      receive ok
                      now my senior decided to change the machine and try to solve the problem in the workshop if we can still recreate the same problem.
                      thanks to all!
                      • costd
                        • Jan 2008
                        • 409
                        Not exactly the same machine (ours was a 2230) or exact same issue (ours would fail to TX and lock the system) but:
                        We cleared the 3 sectors on the HD used by the system for memory storage, and it now works. Would not hurt anything to try:
                        1. Service Mode
                        2. Function>System
                        3. CHK-TYP (enter 1) then ok - will get active&ok
                        4. Chk-TYP (enter 2) ...
                        5. CHK-TYP (enter 3) ...
                        6. System should do a recycle/reboot. If not, do a power cycle.
                        If any of the CHKs do not get an OK, you will need to replace the HD & system software.
