Canon IR ADV C5235i error E732-9999 , E748-9000
  • Su0000
    • Mar 2024
    • 6
    Canon IR ADV C5235i show error E732-9999 , E748-9000 How to fix it?
  • copier tech
    • 8163
    • Check all the scanner connections, like the HDMI cable on the side this can work loose.
    • Code: E732-0001
    • Description:Error in scanner communication
      Error in DDI-S communication
    • Remedy:1. Check the connector connecting to the Scanner. 2. Check the power of the Scanner ->whether to perform initialization at start-up? 3. Replace the Rcon, the Scanner Board or the Main controller PCB 2. Update the system software
    • Code: E748-9000
    • Description:System error
    • Remedy:Update system software
    www.printerfirmware.co.uk
