IR 1025 Black line
  • RHodg57
    • Dec 2013
    • 191
    IR 1025 Black line
    Working on an old IR1025 and have been forever but never seen a problem like this.
    Black bar in cross feed direction that shows up on 10% of copies made.
    I am waiting on a drum unit to come in to see if that helps but have never
    seen a drum on one of these do that.
  • Brian8506
    • 1664
    Re: IR 1025 Black line
    I think the drum will fix that.
    • jamesdrago
      • 2
      Any old timers ever seen this?[ATTACH=CONFIG]50053[/ATTACH]
      Depends on the copy count maybe the dv unit
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5007
        This line is definitely visible if you look at the drum, charge roller or even fuser.
        • Brian8506
          • 1664
          It's in the cross feed direction. I'd replace drum. Could be dv but less likely.
          • copier tech
            • 8132
            As this is a SEF model & the line is cross feed its not your typical drum/blade issue.
            • Venom
              Technical/IT Support
              • Nov 2009
              • 765
              Looks like may be a cracked bushing on dev unit (drum to sleeve spacer). the line occurs when the mag roller arcs to the drum. Replacing drum and developer unit would resolve it.
              IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
              • Brian8506
                • 1664
                So did you fix it?
