Canon 5240 color off.
  • Joe Foe from Buffalo
    • 399
    Magenta is off more on one side of copy compared to other side sample
    This gallery has 1 photos.
    • 399
    Same original flipped around on the expert or glass. Sending happens on internal service mode test
      • 399
      Internal test
      • doktor
        • 214
        https://www.copytechnet.com/forum/te...-fail?t=125671
          • 399
          Thank you...but tried swapping itb units and swapped magenta drum with cyan no change.
            • 399
            Also interesting sevice test "AT-Img x" fails
            • copier tech
              • 8144
              Clean the patch sensors.
              Update the firmware
              Run DC-CONT CLR.
