Bad drum? Developer? Other?
  • bret@cos.flag.org
    • Jun 2020
    • 99
    Hi All,
    I'm looking for any opinions on what this most likely is.
    I recently replaced the cyan drum so I don't think it's that. Also the ITB cleaning blade was recently replaced.
    An idea is maybe the cyan developer?
    Any other ideas of what this might be?
    Machine is a Canon IR ADV DX C5760. Firmware updated to latest as of about 3 months ago. General cleaning done about 3 weeks ago.
    The sample image is a document where this happened which the text was cut off so I could post the blue part. The document is double-sided so you can see some of the text from the other side of the page. That is not a part of the print defect.
    The feed direction of the image is toward my thumb.
    Thanks,
    Bret
  • GIUBOSS
    • 1437
    Re: Bad drum? Developer? Other?
    Originally posted by bret@cos.flag.org
    Hi All,
    [ATTACH=CONFIG]50130[/ATTACH]
    [ATTACH=CONFIG]50131[/ATTACH]
    Thanks,
    Bret
    Always consider the PM counter of wearing parts. Most likely the developer
    • Drivee
      • Nov 2020
      • 322
      If OPC is new. Then is DEV section. What is count?
      • bret@cos.flag.org
        • Jun 2020
        • 99
        Hi giuboss and drivee,
        The count overall is a bit over 600,000.
        This issue started before the drums were replaced, and continued afterwards.
        I agree that this must be the cyan developer. I'm getting one and will replace it.
        Thanks for your input.
        Bret
