I looked up the part for the harness to the thermal cutoff switch TP2 and there is no item number. Does anyone know the part number, it is listed as J3203 in the diagram - no reference to part number?? Strange? Does anyone have a part number for this?
Canon IR8105 tp2 thermalswitch harness
Re: Canon IR8105 tp2 thermalswitch harness
We didn't have this model. Only the advance series has model 8105. If you thought about advance, everything is included in the set as shown in the picture.
FM4-5158-010 CABLE, FIXING DC DRAWERPractice makes perfect
If you want something done right, you have to do it yourself
The item I'm looking for is a wiring harness (pair - 2 wires) on the Canon IR8105 fuser unit, thermal switch harness which has 2 screw contact connections to hook up to the actual thermal switch. See diagram lower left most portion of the diagram is the harness needed. Does anyone know how to get the part number?
Canon IR8105 Thermalswitch harness - lower left small harness.jpgComment
Its in version 3 of the part catalog FM1-U981-000 Cable,Thermoswitch picture says it goes to connector J3203.Comment
