Canon IR8105 tp2 thermalswitch harness
  • skibum
    Independent Service Tech
    • 231
    I looked up the part for the harness to the thermal cutoff switch TP2 and there is no item number. Does anyone know the part number, it is listed as J3203 in the diagram - no reference to part number?? Strange? Does anyone have a part number for this?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: Canon IR8105 tp2 thermalswitch harness
    We didn't have this model. Only the advance series has model 8105. If you thought about advance, everything is included in the set as shown in the picture.
    FM4-5158-010 CABLE, FIXING DC DRAWER
    • skibum
      • 231
      IRA 8105 is correct. What page is Fixing DC Draw?
      • skibum
        • 231
        810 figure 7 Found it. Thanks!
        • zoraldinho
          • Mar 2008
          • 5013
          No problem.
          You just got a green card, too.
          • skibum
            • 231
            The item I'm looking for is a wiring harness (pair - 2 wires) on the Canon IR8105 fuser unit, thermal switch harness which has 2 screw contact connections to hook up to the actual thermal switch. See diagram lower left most portion of the diagram is the harness needed. Does anyone know how to get the part number?
            • 20 year tech
              • May 2014
              • 577
              Its in version 3 of the part catalog FM1-U981-000 Cable,Thermoswitch picture says it goes to connector J3203.
