IRC 3200, Color Reg trouble
  • williamlozada93
    • Aug 2008
    • 4
    Hi, I have a trouble in IRC3200 I cant adjust color register in service manual there isn't instructions for it.
    Some one can help me?
  • kwazimoto
    • Jan 2007
    • 199
    there is no adj in service mode.. first clean sensors above a itb on the right side of machine.. .check connection on the sensors .. if that does not work the remove itb belt asm then the belt and clean the itb drive rollers on the inside of the unit.. if that still does not work replace the itb belt and clening blade asm..this machine self adj color reg..
    • williamlozada93
      • Aug 2008
      • 4
      Thank you so much for your help.
      • Irish
        • 110
        Kwaz is bang on ... It is simply the belt slipping.. Usually caused by excess toner getting between it and the drive roller ... Drums with high volume can drop toner and cause this even though the quality is ok.....
        • SCREWTAPE
          • Aug 2025
          This issue is more than just excess toner at times, other causes are lasers, DC-controller,firmware. Try clearing DC-CON and put back the values for dc con.
          • jtecks
            • Dec 2008
            • 13
            Once again screw is right. Had blurred image after doing all mechanical stuff. Canon said clear dcon. Worked like a champ. Cams on back of drum units out of sync. There is a way to start them close to position in tech pub or service man
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              Another physical thing to check/replace, is the drive gear on the ITB drive roller, the cluster & driven gear on the copier itself. A little play in the ITB gear sets up the same scenario as the dirty belt and rollers. Just played with one this morning....
              FG6-9662-000 swing gear asm
              FU3-0546-000 42t gear
              FU3-0266-040 gear
              • mycopier
                Service manual irc3200
                I'm looking for Service Support tools & SST Software for Canon iRC3200.
                Any help would be Great
                Thanks in advance!
