IR330
  • Brian8506
    • 1665
    IR330
    IR330 with E-1 finisher. Goes into jam occasionally after paper exits finisher. No jam in machine. Display says slide finisher away from machine and thats all you have to do to clear jam message. Jam code 0081. Anybody else see this?
  • kwazimoto
    • Jan 2007
    • 199
    check to see if the mode is in for the tention of the drive belts. FB6-2734-000 part nuber for the leaf spring
    • SteveO
      Yea there is an update leaf spring as mentioned above. Sometimes you need to adjust the tension on the belt if the leaf spring has already been installed.
