hello teachers I have a paper jam problem in the adf, the paper jam code is 0063. I cleaned the sensors, wheels, adf rollers and adjust the sens init, but the problem persists.
when you run the option
feeder cleaning the sheets go through normally in the adf, but when I start to make copies using the adf it makes as if it wanted to pull the paper and instantly it jams and gives the message of paper jam.
