Move the Canon C5235
  • carlsson
    • Apr 2021
    • 35
    [Misc] Move the Canon C5235
    I am about to move the beast one floor. I have bought two "carrying straps" (don't know the english word, it's meant to help with carrying heavy stuff), but I wonder:
    Are there any more carrying handles on this machine but the ones on the left (behind the plastic covers)? I can't find any others, and there's nothing mentioned in the manual, and Google gives nothing...
  • wcanonw
    • Aug 2014
    • 404
    Re: Move the Canon C5235
    hello on the side sides there are some metal handles, but you have to pry to remove the rectangular caps with a knob or flat screwdriver
    • wcanonw
      • Aug 2014
      • 404
      1, 11, 12
      • copier tech
        • 8172
        This is a very heavy model.
        When I move these I take the time to remove the scanner, DF, fuser, process unit & 4x paper trays this helps with the weight & doesn't take too long to remove/refit.
        • carlsson
          • Apr 2021
          • 35
          I started to disassemble the top cover wit the ADF etc, but it seemed to be extremely complicated!? Or am I overthinking it?
          I have removed the paper trays, should probably remove the fusers etc also.
          • carlsson
            • Apr 2021
            • 35
            So there are handles on both sides! But htf do I reach no 11 and 12...!? 🤔
            • carlsson
              • Apr 2021
              • 35
              Thanks for all your input.
              It wasn't that hard at all to remove the ADF unit, but eventually we decided not
              • copier tech
                • 8172
                Good idea as I said this is a heavy model.
                However in future if you have the service manual remove the scanner & DF as one unit makes it a lot lighter to carry.
