Canon 6255 blur images at the start of the day
  • Uniquer
    • Feb 2022
    • 30
    I have many advance canon 6255/6255/6275 have the same problem that print blur images the first 50 pages around then print normally. If i run clean drum program at the start of the day it prints perfectly from the first page. I already replaced the drum unit and the same problem. I have to run clean drum every day. Any suggestions thank you
    This gallery has 1 photos.
  • nicknt82
    • Nov 2011
    • 155
    Maybe your machine put on high humid environment. check this value of humid sensor on machine and try to move it to another place
    • Brian8506
      • 1664
      If it’s cold there the laser could be getting fogged
      • smiley
        • Aug 2008
        • 615
        Have you turn on drum and paper heater switch at the back of the machine?
        there is no glory without sacrifice
        • Uniquer
          • Feb 2022
          • 30
          Yes but no change at all
          I have suspects to paper i ll try and give feedback
          • smiley
            • Aug 2008
            • 615
            Try not to turn off the main power switch over night. Just turn off the control panel power button and try to make a copy the next day soo that the paper and drum heater will not turn off.
