Canon ir 3245 margin fault
  • zawmyo201210
    • Oct 2022
    • 51
    [Jamming] Canon ir 3245 margin fault
    On my machine, the image output area is unstable and moving. Sometimes the images are cut off and the machine is always cropping.
    This is error print and glass copy same.
    So I am change registration Cluth. Same error.
    Please advise what else Kim needs to do.
  • Brian8506
    • 1664
    Is it both trays? Solenoid in paper feed unit could be sticking. Reg roller could be worn. Usually it’s the clutch
    • bobburnsreb
      • Mar 2015
      • 233
      TRY Copier>Adjust>Feed Adjust>Loop-CST
      • zawmyo201210
        • Oct 2022
        • 51
        Yes, 4 tray and bypass. It is same.
        • zawmyo201210
          • Oct 2022
          • 51
          Yes. I am try
