Canon IRADv 5560
  • effingham141
    • Oct 2012
    • 10
    [Error Code] Canon IRADv 5560
    Hi all,
    I have a Canon IRADv 5560 which won't let me go into download mode via 2.8 or 1,7, it just restarts and goes into restart.
    It originally came up with an E602 error., which cleared itself.
    Any ideas?
    Thx
  • bobburnsreb
    • Mar 2015
    • 228
    Try 2+4 mode and see what the results are.
    • effingham141
      • Oct 2012
      • 10
      Hi i will try this and let you know bobburnsreb.
      Thx
      • GG CANON
        • Oct 2024
        • 23
        change HDD
        • effingham141
          • Oct 2012
          • 10
          Hi GG CANON,
          I have tried a new HDD, but it goes straight into an error state E602.
          I cannot download firmware onto it via usb thumb drive or SST, as the printer will not allow download mode. ( 1,7 or 2,8 )
          It is working with the old HDD but i don't know how long for. but even with the original HDD working i still cannot access the download mode.
          Also i have cleared MN Con, and DC Con.
          Thanks for the suggestion though.
          Bizarre.....yep?
          Wondering if it could be the dreaded Main controller...🙈
          • bobburnsreb
            • Mar 2015
            • 228
            When you replace the hard drive do you follow the attached procedure?
            • effingham141
              • Oct 2012
              • 10
              Hi, probably not in that order of procedure, but i will give it a try and let you know.
              Many thx's!
              • nicknt82
                • Nov 2011
                • 155
                Many thx's!
                Hello, this problem not from HDD. Add my whatapp number, i teach you how to check something
                • effingham141
                  • Oct 2012
                  • 10
                  Hi Nicknt82
                  What is the time difference where you are?
                  i'm in the UK
                  Thx
                  Steve
                  • zoraldinho
                    teacher-guide-expert-guru
                    • Mar 2008
                    • 5001
                    The basis of this forum is sharing information for other techniques as well.
                    Thanks!
                    • nicknt82
                      • Nov 2011
                      • 155
                      Hi Nicknt82
                      i'm in the UK
                      Thx
                      Steve
                      Yes. My time zone is GMT+7.
                      • nicknt82
                        • Nov 2011
                        • 155
                        Thanks!
                        yes, i must do video call directly for understanding problem
                        • MOLICN
                          • Mar 2024
                          • 26
                          E602 codes are all hard disk codes, and some are caused by FLASH electronic hard disks.
                          If the boot press 2+8 is invalid, you can only repair the electronic hard disk and then upgrade the operation.
