Canon IR C5535
  • Drivee
    • Nov 2020
    • 322
    Canon IR C5535
    Is there any settings which will make premature OPC fail on Canon C5535. I have cite with 20 printers, the OEM OPC's fail before stated yield. Some of them fail after 70k and some after 300k. I wonder, is there any settings which can cause this. Maybe bigger charge on OPC or similar.
    Looking fail OPC, it is clear that wiper blade is dirty and he will not clan OPC so the user will see lines on print test. It is easy to fix but it is strange that just after 70k I need to repair or replace OPC. They are not cheap.
  • GIUBOSS
    • 1435
    Re: Canon IR C5535
    In my opinion, the performance of the drum depends on various factors such as the paper, the environment, stress from use, the cleaning blade itself can damage it. The expected duration target is not always achieved even on other models. Unless there is a tech bulletin correcting the pcu cleaning system.
    • teckat
      • 16083
      Re: Canon IR C5535
      It's all about % of toner coverage on paper.
      In color products, when u go over 8% coverage on LTR size paper, and exceed monthly volume, your printer maintenance starts to break down, even more when u use third party products.
      • charm5496
        • 2387
        Re: Canon IR C5535
        There is an old style drum that has been updated by Canon since this devices initial release. The primary charging rollers were failing and falling apart causing these drums to fail early. The old ones were were a black foam material and the new ones white and I have had very few issues with the updated drum units.
        • techandtrader
          • Jun 2016
          • 332
          Re: Canon IR C5535
          If the drums wearing out are the updated style then finding out what they are printing and toner coverage is going to be important for the dealer. It warrants an increase in price of the maintenance agreement/ click charges.
          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
          • Drivee
            • Nov 2020
            • 322
            Re: Canon IR C5535
            I don't know, why dealer still selling them. It caused a lot a problems on cite.
