Having a problem with this 2010 seeing the network card. The card is showing activity and is connection to the network, however when going to the network settings I get the error message. "Network requires additional equitpment." This function used to work fine untill IT redid the mac address reserve and the ip in the copier started to go hay wire.
In service mode what switchs needs to be activated for the copier to see the network card.
Thanks,
Scott
Thanks,
Scott
