Need a little help on a Canon ImageRunner c5235 Advance
  • judgedredd
    • Feb 2024
    • 47
    #16
    How do I get rid of the ID codes?
    • copier tech
      • 8144
      #17
      Check to see if this is enabled.
      • ReproKev
        • 273
        #18
        PCL and PS printing were options on that machine. Your machine may not have either of those options, in which case you need to use the UFRII driver. That's assuming you don't have a Fiery/Colorpass print server box mounted on the back of the machine. In that case, don't use the c5235 driver, use the correct Colorpass driver.
