Canon C60 White Spots
  • famerdave
    • Dec 2021
    • 1
    • 22999
    Re: Canon C60 White Spots
    I've seen primary transfer cause this issue on Konica Minoltas. The reason that you don't see a repetitive pattern is that the primary transfer belt is ~120cm long ... way longer than any single sheet of paper. =^..^=
    • Hishamawada
      • 174
      Your issue is with the itb . Open it and they will be visible with the eye.
      When u replace it make sure to clean the assembly properly.
      Sent from my M2101K6I using Tapatalk
      • romario
        • Jun 2020
        • 192
        your problem is in the primary transfer band, (IBT) you have to replace the transfer band
        thanks
