help run Boot System Error Diagnosis Tool for IRA8505
  • TEST10
    • Jun 2010
    • 69
    I understand that in most IRA models, to access Boot System Error Diagnosis Tool -------- Turn ON the Main Power Supply Switch while pressing the Control Panel Power Supply Switch.
    But in the IRA8505 model, it does not have a power supply switch in the control panel. How do you do it then?
    initialization failure / saying Checking data... (IRA8505)
  • copier tech
    • 8165
    Re: help run Boot System Error Diagnosis Tool for IRA8505
    What error or fault do you have ?
    โ€‹
    • giogi
      Engineer senior
      • Jan 2016
      • 181
      hold down keys 2 and 4 and turn on the device
      "Knowledge is a source, but unfortunately ignorance is a sea."
      • TEST10
        • Jun 2010
        • 69
        Enviado desde mi SM-N9600 mediante Tapatalk
        • TEST10
          • Jun 2010
          • 69
          Controller System Error Diagnosis Tool / also diagnostic boot?
          my problem, "Checking data" message on power-up, and it doesn't get past that screen!
          • onlyinnewfoundland
            • Apr 2013
            • 235
            Try getting the firmware on USB stick and reloading. Boot using 2/8 keys. Flash using overwrite all.
            • TEST10
              • Jun 2010
              • 69
              Thanks for the advice, where can I download !? can I request it in a forum?
              • TEST10
                • Jun 2010
                • 69
                [QUOTE = onlyinnewfoundland; 2013261] Intente obtener el firmware en una memoria USB y vuelva a cargarlo. Arranque con teclas de 2/8. Flash usando sobrescribir todo. [/ QUOTE]
                Thank you very much, it was the solution to the problem
