Unable to use certain parts of control panel DXC3725i
  • nathicana
    • Aug 2008
    • 335
    I'm trying to help another tech with this situation. The start, counter, home, settings reg, scan and send shortcut are all inactive and appear shaded as though disabled by design. Default screen is copy and most settings such as paper selection work. Machine will go into service mode and print pg pages so panel is working in the background, just not for MFP function.
    No alarms or errors and machine is reporting to snapshot. Status shows no jobs in queue. No fax system. I don't think they have department IDs.
    I don't know if we can browse to the web interface or get into download mode or print to the machine but I'm guessing yes. We ordered a hard drive but I'm wondering if there is a security feature turned on or something. One time the tech turned off the machine and restarted it with the network cable unplugged and was able to run one copy then the problem came back.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Unable to use certain parts of control panel DXC3725i
    It's sounds like bad display pcb.
    You can try to calibrate display first.
    Service mode then eight time press no:5
    Also can be bad hdd.
    • copier tech
      • 8164
      Try updating the system software sounds like it has become corrupt.
      โ€‹
      • nathicana
        • Aug 2008
        • 335
        The problem was the hard drive, we replaced it rather than try to resurrect it.
        We weren't able to gather the dcm file because settings registration was not functional in the web interface or the device
        • copier tech
          • 8164
          Thanks for the update.
          Surprising the HDD failed so soon on a DX model.
          โ€‹
